document.write('
'); document.write(''); document.write('
dwright
dwright'); document.write(' '); document.write(''); document.write(''); document.write(''); document.write(''); document.write(' '); document.write(''); document.write(''); document.write(''); document.write(''); document.write(' '); document.write(''); document.write(''); document.write(''); document.write(''); document.write('
'); document.write('       Step Motor Basics
'); document.write('Step motor basics calculator / converter featuring torque, speed, inertia, distance, resolution, and some common industry terms. Share across most any website, including Facebook, Engineering Exchange, iGoogle, Yahoo, Netvibes and more. You can also share and email this widget and even use on your desktop using the Vista Sidebar or Yahoo Widgets.'); document.write('
'); document.write('       Design World Network News
'); document.write('A compact multi-tasking news feed widget featuring News and Editorial from across key sites including Design World, MakePartsFast, Sensor TIPS, MotionControl TIPS, and Coupling TIPS.'); document.write('
'); document.write('       Thermodynamics Calculator
'); document.write('The thermodynamic basics calculator widget features heat capacity, linear thermal expansion, temperture conversion basics and common terms.'); document.write('
